B&K AVR 307 7 x150w Receiver
0 Members and 1 Guest are viewing this topic. Read 2872 times.
murphy11
« on: 8 Oct 2007, 09:16 pm »
http://www.hometheaterhifi.com/volume_9_2/b&k-avr-307-receiver-5-2002.html   $3495 original Sell Price $900. Should have one year remaining on original 5 year warranty.
« Last Edit: 9 Nov 2007, 10:03 pm by murphy11 »
murphy11
Re: B&K AVR 307 7 x150w Receiver
« Reply #1 on: 18 Oct 2007, 04:42 pm »
Bump - new price $950. This 7 x 150 receiver can be upgraded by B&K for $499 to change the processing in the 307 and have it process the same as the 507 series 1. Here is the 507 series 2 http://www.bkcomp.com/fileadmin/content/content_products/manuals/Past/HT/AVR507_505_manual.pdf
Receiver is in great condition - I just don't use it as much as I used to and want to free up some funds for a new hobby. 1 year remaining on original 5 year warranty. Heck, if you don't need the processing - think of this as a great price on a 7 x 150 amp that can be used with power hungry speakers.
Also a cool feature of this receiver is room equalization - I stole the following from the user manual
Room Equalization
Usually these settings may be left set to the factory defaults. However, theses settings allow you to correct or
reduce the various tonal errors that occur during reproduction of audio in a home theater.
The room equalization menu allows for two types of adjustments.
1) A notch filter that allows you to ‘Notch’ or reduce the accentuated bass created in a room with multiple
speakers (available during THX listening mode) (see Setting up the notch filter).
2) Variable bass and treble controls (not available during THX listening mode) allow you to configure a default
‘Variable EQ’ setting that best suits your listening room needs.
murphy11
« Reply #2 on: 9 Nov 2007, 10:03 pm »
Bump - new price $900
