Khartago Mono....dead!
0 Members and 1 Guest are viewing this topic. Read 1741 times.
s_cervin
« on: 7 Oct 2007, 12:53 pm »
Fired up the HT last night and when the movie started playing had no sound from the center.  Checked everything, last check was to just put the left channel RCA on the center and still nothing.  Power light is on and it has been kept on based on suggestions here.  Anyone have any other ideas before I try Klaus tomorrow??
SC
s_cervin
Re: Khartago Mono....dead!
« Reply #1 on: 7 Oct 2007, 01:04 pm »
Found it.  S14 and S11 fuses blown.  Hopefully Klaus can get me out a few new ones prior to RMAF.
s_cervin
« Reply #2 on: 7 Oct 2007, 03:13 pm »
Fast blowing 6.3A 250V??  I'll search here.
Jim N.
  • Who you callin' an audiophile?????
« Reply #3 on: 7 Oct 2007, 06:50 pm »
I don't know if the Khartago uses the same fuses as the Stratos. I have a Stratos and Klaus told me to use 5, 6 or 6.3 amp 5x20mm fast blows on it.
Wolfman
« Reply #4 on: 8 Oct 2007, 11:49 pm »
Good luck finding them at a Ratshack,the ones around here certainly didn't have them. I had to go to an electrical supply store.
s_cervin
« Reply #5 on: 21 Oct 2007, 02:31 am »
Bummer.....fuses didn't do it.  I guess I'll be sending it back for a fix.
