Turning off tube amp - Any concerns?
0 Members and 1 Guest are viewing this topic. Read 2288 times.
mfsoa
« on: 3 Oct 2007, 01:04 am »
Hi all,
Is it a problem to turn off a tube amp with the source playing? It makes that fizzling-out sound. I hear no sharp transients or high-freq stuff, but could this be bad for speakers or the amp (or tubes)?
-Mike
(And don't you all like my new avatar better? It keeps your monitors smudge-free!)
IronLion
Re: Turning off tube amp - Any concerns?
« Reply #1 on: 3 Oct 2007, 01:11 am »
It is my general practice with any gear to always turn the volume all the way down on an amp before turning it off; also, if there's a mute function, I turn the volume down, mute it, then turn it off.  As I understand it, you always want to turn off the amp first and work your way back to the source as you turn things off.
mjosef
« Reply #2 on: 3 Oct 2007, 01:27 am »
I always like to turn the amp off while music is playing...sorta like emptying the tank...  :lol: Plus you get to hear the music gradually ...disappear.
On start up I get a fresh tank (charge) ...lol
Dunno if it hurts anything, never had any problems.
JohnR
« Reply #3 on: 3 Oct 2007, 12:30 pm »
I can't think of why it would be bad. The signal is relatively small compared to the DC/bias voltages.
