0 Members and 1 Guest are viewing this topic. Read 7892 times.
Recently I've read that smaller 5" woofers have advantages over 6 or 7" counterparts,namely faster decay and more detailed midrange.Those would be important to me.They also have disatvantages,mostly weaker bass-how important is this if used with a sub?I've read good things about these two drivers : Seas W15CH001 and ScanSpeak 15W/4531G.Would they work in a 2-way or an mtm arrangement in a bookshelf cabinet?
If you did an MTM with Seas W15CH001,how much would that cost?
Well,something that measures up to the woofers..The same fountek ribbon if it would match them well,or something else good if not.It looks like something out of my price range but who knows how much money will I have when the time comes to spring for some speakers,so I'm just satisfying my curiosity.
You wouldnt offer it as a kit though,right?Only the popular designs go as kits?
... you'll need in most cases a higher crossover point than a 7" would. A 5" will usually (not always) give you more flexibility in choosing a tweeter.
Quote from: Rick Craig on 2 Oct 2007, 08:53 pm... you'll need in most cases a higher crossover point than a 7" would. A 5" will usually (not always) give you more flexibility in choosing a tweeter.Just to continue the interesting discussion:Rick, in a two-way design (or a Galena) wouldn't the new Fountek NeoPro5i ribbon nicely complement the 7" Revelator by allowing a lower crossover frequency (down to 1kHz, according to specs!), thus solving the theoretical advantages of a 5" at the top of its frequency range? Have you thought about this combination? Are there any disadvantages?The famous and very expensive Arial 20T combines a similarly large rectangular ribbon (105mm) with a 7" midrange.
Sorry for being a newb,what is a "vertical window" exactly?I'm guessing its something that limits the listener's position to a certain area,but in which way exactly?
why? Did I not understand correctly that its about the height?If I seat in the same chair while listening with a well matched speaker stand to put the tweeter on my ear level,why head in a vise?What is the vise supposed to do?
