Building the LS-9's...Need recommended veneer sources
0 Members and 1 Guest are viewing this topic. Read 2341 times.
S Clark
  • Guest
I'll be building a set of LS-9's and need to to make them look really nice or Mama won't be happy (they are really big- I don't need big and ugly).  Where do you get 80" sheets with nice figure at a reasonable cost?
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
Re: Building the LS-9's...Need recommended veneer sources
« Reply #1 on: 2 Oct 2007, 05:37 pm »
I've got tons of great veneers off Ebay in the past ...
S Clark
  • Guest
« Reply #2 on: 2 Oct 2007, 05:49 pm »
any particular vendor that you remember?
Cacophonix
« Reply #3 on: 2 Oct 2007, 05:52 pm »
check out rosebud veneers on ebay. I think he's the one who sells veneer to Jim Salk....so he's gotta be darn good.
S Clark
  • Guest
« Reply #4 on: 2 Oct 2007, 07:27 pm »
The rosewood does look nice, but only some was veneer, the rest plywood- which could work fine glued to the sides.  The main problem is the quantity of veneer needed.  These things need about 8'x11' .  I'll keep watching ebay, but I suspect that I'll have to buy something this large from a dealer. Hope I'm wrong as ebay should be cheaper.
Cacophonix
« Reply #5 on: 2 Oct 2007, 07:36 pm »
Then you might want to check out his site, http://rosebudveneer.com/, and buy directly from him instead of going through ebay. I've bought a few times from him ... good quality veneer at very very reasonable prices. Only issue is that he deals with raw veneer.
RAW
« Reply #6 on: 2 Oct 2007, 08:29 pm »
This Ebay selling I recommend highly.
We have over 800 ft of veneer we have puchased from this seller.Great product as well as shipping.
Issues real wood veneer is not what I recommend for students.
Use a paper backed veneer and you will have great progress with the kids.The RAW veneer is breakable ,can have glue blead threw and chips very easy.
So for first timers I always recommend the paper backed veneers.
http://www.formwood.com/sale_items.php
Some great deals to be had here from time to time.
A few pairs of speakers can be built with this OAK. 10ft sheet
Oak, White Flat Cut  9 pcs  10 x 4  Bal Book  20 Mil paper  A WHO9C $67.15
Add in the cost of Bambo $25.00 sheet CHEAP!
http://www.mastergardenproducts.com/bambooveneer.htm
Bill Baker
    • Musica Bella Audio
« Reply #7 on: 2 Oct 2007, 08:57 pm »
I always had great luck buying mine from Oak Wood Veneer. They even have the 3M adhesive backed but it's only 24" wide?
http://www.oakwoodveneer.com/
BrianH
« Reply #8 on: 3 Oct 2007, 07:12 am »
http://www.macbeath.com/
http://www.woodworkerssource.net/
I have bought wood in the stores from both of these stores and like both of them. They both carry a lot of the exotic veneers.
Brian
Hank
« Reply #9 on: 3 Oct 2007, 11:01 am »
Myself, Brian Bunge and others have been using Tape-Ease for a few years.  Take a look and compare prices.  Brian and I can vouch for their service and quality:
http://tapeease.com/10_mil_%20veneer.htm
Even if you are experienced, I highly recommend using paper-backed if you are going to wrap the veneer around rounded over cabinet corners. :)
