Fuses
0 Members and 1 Guest are viewing this topic. Read 2145 times.
timothyharnett
Fuses
« on: 1 Oct 2007, 11:24 pm »
Has anyone tried the Hifituning fuses. If so, did they make a difference?
What is the size and spec of the fuse used,in a 9 v2 se?
cryotweaks
  • Funny name. Serious audio.
    • TweekGeek.com
Re: Fuses
« Reply #1 on: 2 Oct 2007, 12:33 am »
Yes, I tried the HiFiTuning fuses in the pre V2 amps and it did make a worthwhile difference.  The rest of my system was pretty tweaked out as well however.  Wayne of Bolder Cables also had some silver plated ceramic fuses that were very close in performance as well. I do not know if he still offers them.
timothyharnett
Re: Fuses
« Reply #2 on: 2 Oct 2007, 08:40 pm »
Thanks, any idea of the spec of the fuse? Which, do I order?
sac8d4
Re: Fuses
« Reply #3 on: 2 Oct 2007, 09:11 pm »
to give you some other fuses to compare them to, i have heard great things about Isoclean fuses www.isocleanpower.com and you might try acme audio  www.acmeaudiolabs.com (which i think are the fuses that bolder cables uses)
cryotweaks
    • TweekGeek.com
Re: Fuses
« Reply #4 on: 2 Oct 2007, 09:38 pm »
The fuse spec is written on the side of the fuse and on the fuse holder for the Nuforce amps.  Mine says "T5A 250V"
beachbum
  • Vinyl Delivers all of the Music
Re: Fuses
« Reply #5 on: 4 Oct 2007, 02:52 am »
timothyharnett when you get your tuning fuses let us know what difference they make, ive been contemplating that tweak my self.
