Jelco Tonearms
0 Members and 1 Guest are viewing this topic. Read 2798 times.
WEEZ
Jelco Tonearms
« on: 1 Oct 2007, 07:09 pm »
These arms have been discussed here in the vinyl circle before. I stumbled upon what appears to be a U.S. source for these arms:
www.finestcable.com/tone_arm
So if you're looking for a well made arm at a reasonable cost....here's an option. It doesn't appear that they handle the 750D arm as shown on the Jelco website; just the 250 series. The 750D can be viewed at www.jelco-ichikawa.co.jp/e_tone_arm.htm
(I am not affiliated, nor endorsing....just an FYI) As has been mentioned before also; Elusive Disc has the remaining inventory of the Audioquest branded arms. www.elusivedisc.com/products.asp?dept.=1352
WEEZ
Wayner
Re: Jelco Tonearms
« Reply #1 on: 1 Oct 2007, 09:29 pm »
GOOD JOB WEEZ!!!!!!!
These tone arms are damn fine if you ask me. I may source one for a DIY table I am considering.  :drool:
W
WEEZ
Re: Jelco Tonearms
« Reply #2 on: 1 Oct 2007, 09:36 pm »
Yup. Good bearings, good wiring, good machining work :)
WEEZ
(note: the 250 series are not fluid damped, but they do have adjustable VTA..unlike a Rega. the Audioquest and the 750 Jelco have fluid damping capability...)
Wayner
Re: Jelco Tonearms
« Reply #3 on: 1 Oct 2007, 09:49 pm »
My Rega p3 is showing up tomorrow.......
W
WEEZ
Re: Jelco Tonearms
« Reply #4 on: 1 Oct 2007, 09:56 pm »
Wayner,
Try to find a re-tipped Dynavector 10X4 or 10X5 for that P3. Add the Rega 2mm spacer. Silly good. :)
WEEZ
