0 Members and 1 Guest are viewing this topic. Read 18027 times.
Perhaps we (someone who knows what they're talking about) should clarify why I always see BSC brought up in context of single driver speakers (and not other speaker types).
I suppose that in theory only infinite baffle designs (or those with drivers that don't go low enough to be affected) wouldn't need BSC.
It (BSC) should be part of the overall design of any speaker, not addressed as a separate "problem".
Anyone trying to design a speaker will not have found a bit of help in these discussions.
Turbo, Excellent. You seem to get it too. I bet you did not read that...... "6db of BSC is almost always too much. Real systems are in rooms with walls, and reinforcement. 3-4db typically sounds better, unless you're building speakers for your patio" in a book or on the internet either did you?
BTW....I should mention "Chrisby" (I am pretty sure) asked me a few years ago how I dealt with BSC. I was for a couple minutes confused! I NEVER had even thought of it as a separate issue! I had always just dealt with "response using a narrow baffle". It took me a minute or two to realize what he was talking about! EVERYTHING about my little speaker is for a reason, and that includes the narrow baffle and the overall resulting response. They are corner horns, remember. I hope that is clear enough.
Turbo,I like you already. We agree on a very simple concept. It should be obvious to anyone (serious) in this field. I hope.And you got the concept of what I was trying to say perfectly. I wish I could have done it in so few words!
