Bryston SP 1.7 HELP
0 Members and 1 Guest are viewing this topic. Read 3853 times.
Tanner
Bryston SP 1.7 HELP
« on: 4 Sep 2003, 09:05 pm »
Was playing with the THX mode while watching a DVD. Pressed the THX button to get out of THX mode but THX led stays lit and display sill reads + THX. What am I missing here.
jethro
Bryston SP 1.7 HELP
« Reply #1 on: 5 Sep 2003, 01:20 am »
Try the "SURR" button on the remote. There may be a delay if you have no rear speakers. I was also surprised that the "THX" button was not a toggle. I'm going to have to re-read my manual.
Tanner
Bryston SP 1.7 HELP
« Reply #2 on: 5 Sep 2003, 06:30 am »
jethro, thanks that did it. :D
stp1200
Bryston SP 1.7 HELP
« Reply #3 on: 10 Sep 2003, 08:17 pm »
THX changed their spec between the SP1 and SP1.7 models.  They won't let us implement THX as a toggle function anymore - it has to be a mode unto itself.
The delay is a result of a THX-required error message.  If you are not using back speakers and have no need for EX processing, you can get rid of the error message by going into the 'OS' -> 'EX' menu and changing the EX control setting to 'Disable'.
