0 Members and 1 Guest are viewing this topic. Read 8083 times.
I would probably glue vinyl tiles (don't trust the supplied sticky backing) to the inside walls just for fun. A cheap cop out on constrained damping.
Yeah, it's like $10 for a stack, and hopefully you have some good glue sitting around. I can't get pieces of wood just the right length to be an effective brace, though. I just don't have those skills.
Just another idea for consideration... I saw on the lambda forum where someone mentioned that they used steel rods for bracing and that they preferred it very much to window bracing or dowels. I think they were referring to the threaded rods you can get at the big box, like we use in flexy racks although they needant be as thick. You can basically cut them and pressure fit them inside the box but if you want to glue them in place, I'd use a large diameter washer and nut on the end and tighten the nut so that the washer is pressed against the sides of the box...and use glue on the washer. The rods are quite stiff in their length direction and take up a lot less volume. I really don't think you need to be concerned with them vibrating, because they vibrate at high frequency and this is a sub.
