0 Members and 1 Guest are viewing this topic. Read 7318 times.
I admire your determination, Steve.I believe that you have a lot of work ahead of you to get these two drivers to marry. Judging only by the FR charts, they don't even like each other If your going to cross over as low as 500 hz, your xover better be real good, 'cause as you know that's a critical area and if it isn't damned near perfect, you'll hear it. Personally, I'd try a little higher, say 800-1k and keep the notch and experiment with adding a zobel as well. Whatever order x-over you plan on, remember at 500 hz, that nasty peak of the 15 is only 2 octaves away!With a 2nd order, I can almost gaurantee that it will interfere.If you have spice software it will help alot.
Martin Logan uses Neo 8 (and Neo3) in the Mosaic and Fresco speakers.Crossovers are 450 resp 500 Hz for the Neo 8 in their design.
