gounding RCA jacks
0 Members and 1 Guest are viewing this topic. Read 1813 times.
kac00
gounding RCA jacks
« on: 24 Sep 2007, 08:23 pm »
Hi,
I've read through as much as I can find on grounding for the bugle & PS here.
One question though... should the RCA jacks be grounded to the chassis or isolated from it?
I'm using these from digikey:
http://rocky.digikey.com/WebLib/CUI%20Inc/Web%20Photo/RCJ-031.jpg
My intent is to run earth ground to the chassis and the bugle ground (the one near the inputs) to the chassis. Turntable ground will run to the chassis also. Should these three physically share the same post, or do they just have to get to the chassis?
Thanks a lot,
-Keith
« Last Edit: 24 Sep 2007, 09:50 pm by kac00 »
hagtech
Re: gounding RCA jacks
« Reply #1 on: 25 Sep 2007, 12:41 am »
It is usually best to isolate jacks from chassis.  Chassis ground can come from power cord.  Then it connects to BUGLE at one spot, usually at the inputs.
They do not all need to be same post.
jh
nimrod
« Reply #2 on: 28 Sep 2007, 04:39 am »
I have some questions along these same lines. I have my Bugle board in one Hammond aluminum case, and the P/S in another, identical case, with an IEC inlet for the power cord. Should I connect the ground to just the case, or to the P/S board ground eyelet as well? And, depending on how I do that, how would I connect the ground to my ground lug screw on the Bugle case, which I must have in order to connect the ground wire from my tonearm. Should I isolate the ground lug from the chassis, or ground it to the chassis? Or is it a matter of 'try it and see'? (Clear as mud? :duh:)
hagtech
« Reply #3 on: 28 Sep 2007, 05:13 pm »
Yes, the board should be grounded.  Do it in one spot.  The easy way is to make the ground lug used for TT connect to the chassis.  Use that point to tie the ac line earth, and use it to wire up the PCB ground.
jh
