My ripole project
0 Members and 1 Guest are viewing this topic. Read 3064 times.
zobsky
  • Fringe Lunatic - Dallas, Tx
    • My Audio Blog
My ripole project
« on: 24 Sep 2007, 07:26 pm »
In progress. My main thread  is at diyaudio.com (  http://www.diyaudio.com/forums/showthread.php?s=&postid=1308576#post1308576 )but I figured I'd post here too to draw from and hopefully contribute to the wealth of experience. Basically a dual driver ripole with the cones facing each other, . a.k.a. BMC (Blow Motion Concept)
Code: [Select]
Pyle PPA15
* Power handling: 250 watts RMS/800 watts max
* Voice coil diameter: 63.5mm
* Impedance: 8 ohms
* Frequency response: 27-4,000 Hz
* Magnet weight: 70 oz.
* Fs: 26.7 Hz
* SPL: 90.2 dB 1W/1m
* Vas: 0.321679377 cu meters
* Qms: 2.69
* Qes: .89
* Qts: .67
* Xmax: 6 mm
* Sd (approximate value for a 15" woofer with pleated surround) : 0.0856 m2
* Dimensions:
   Overall Diameter: 0.382524 meters
   Cutout Diameter: 0.352044 meters
   Mounting Depth: 0.152908 meters
Here's a sketchup rendering
Critiques, . .suggestions etc .. welcome . Should I expect this device to be utterly inefficient?
 If I need to add a U-extension at the rear later on, I plan to implement it via a sliding sleeve.
some young guy
Re: My ripole project
« Reply #1 on: 24 Sep 2007, 10:08 pm »
oops, sorry i thought you were making booze :duh:
i'll try to follow on diyadio...
zobsky
    • My Audio Blog
« Reply #2 on: 24 Sep 2007, 10:13 pm »
Now that you mention it , ...  aa
