Easy CD-DA Extractor - Help
0 Members and 1 Guest are viewing this topic. Read 1409 times.
EProvenzano
« on: 22 Sep 2007, 03:54 am »
Good evening gents.
I'm experiencing a slight problem using Easy CD-DA Extractor.
When ripping CD's or converting old file types to FLAC, I'm not able to embed the Additional Meta-data information, specifically the Cover Artwork.
I do have the Enable Metadata box checked off, and don't see any other toggles or switches that should keep this from working.
I'm using Slim Server to view and play my files to a squeezebox.  Don't know what's going on but the album art doesn't show up in Slim Server.
Any ideas?
Thanks all!
Nick B
Re: Easy CD-DA Extractor - Help
« Reply #1 on: 22 Sep 2007, 04:50 pm »
I also use Easy CD and am unable to see cover artwork on Slim Server. I have called Slim tech support twice on this issue and they weren't able to help. The cover artwork does show up on my Media Monkey software.
Double Ugly
« Reply #2 on: 22 Sep 2007, 05:03 pm »
Mike Galusha (mgalusha) has more experience with Easy CD-DA Extractor than anyone I know.  Mike isn't quite as omnipresent as was once the case, so sending a PM may be the quickest way to ensure he sees your question.
Alternatively, Poikosoft has a forum; have you sought help there?
