SP 1.7 problem
0 Members and 1 Guest are viewing this topic. Read 1814 times.
codling
SP 1.7 problem
« on: 21 Sep 2007, 08:27 pm »
HI James/All
Ive got a prob with my processer :( (made 2003)
Just moved up too 7.1 from 5.1, im getting no sound from my new Back Rears.
Have been through the setup procedure, got the BK set to 2 ond not None,i have saved settings, when i run the test tones there is no test tone for the back rears!
Ive also noticed that sometimes when i set the levels for my speakers,and save the settings, it some times reverts back to old settings and i have to re-run the test.
any help would be greatful,checked manual,am i missing something?
Regards Carlos
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP 1.7 problem
« Reply #1 on: 21 Sep 2007, 09:50 pm »
Hi Carlos,
Do you have the EX and ES funtion engaged?
james
codling
Re: SP 1.7 problem
« Reply #2 on: 21 Sep 2007, 09:58 pm »
Just been playing more,
Checked all connections,all fine.got EX/ES set to 'ON'.Back Set to 'two'
1. i press the back button on remote and adjust the back level by .5db .
2.then run test tone again ,the test tone for the back speakers start to work!!  :)
3.then finish the test tones. dvd sound comes back on,no back speaker effect!! .
4. Run test tones again, NO Test Tone For back Again!
then i do the same again from no1. Test tone for backs re-appear!!!
very strange!!! :?
codling
Re: SP 1.7 problem
« Reply #3 on: 21 Sep 2007, 09:59 pm »
Cheers James Just replied above!
 :thumb:
Re: SP 1.7 problem
« Reply #4 on: 21 Sep 2007, 10:15 pm »
Ok -what software do you have?
When it first starts it will say.
Also I assume when you say SAVE you are using the save button on the remote?
james
codling
Re: SP 1.7 problem
« Reply #5 on: 21 Sep 2007, 10:22 pm »
james
James,
OS V.43D
DSP 2.01
Yes i use the save on the remote.
Re: SP 1.7 problem
« Reply #6 on: 21 Sep 2007, 10:54 pm »
OK there is newer software - - Contact Mike Pickett at Bryston and he will assist you.
[email protected]
james
codling
Re: SP 1.7 problem
« Reply #7 on: 23 Sep 2007, 05:43 pm »
Cheers James will e-mail Mike
Many thanks :D
