BlueNote Audio Stibbert - anyone own one?
0 Members and 1 Guest are viewing this topic. Read 992 times.
Big Red Machine
« on: 20 Sep 2007, 11:49 am »
I've had my eye on this CDP for some time and the used ones on Agon are within reach.  Curious if anyone here owns one and can comment on the sound.
carusoracer
Re: BlueNote Audio Stibbert - anyone own one?
« Reply #1 on: 20 Sep 2007, 07:17 pm »
Big Red,
I heard one in MD...very Analog sound it also very sensitive in the early editions to vibrations.
The unit I heard was the second iteration and seemed to be well supported. All the customer service issues have supposedly been addressed.It is very nice looking as well.
I too have looked at this unit but have not pulled the trigger on one.
As always you must hear it yourself to know if it will keep your toes tappin' 8)
mihilli
« Reply #2 on: 20 Sep 2007, 09:10 pm »
I don't own one either but the local reseller brought one to my place and we had a good session with it in my system.
As stated, has a nice warm analogue like sound.
I was very impressed considering the $$$.  If I was looking I would certainly consider the Bluenote.
Didn't notice any vibration issues.
MT POCKETS
« Reply #3 on: 21 Sep 2007, 11:46 am »
I own the BlueNote Stibbert and it is an excellent sounding unit. Deep tight bottom end, silky mids and a top end that is not in the least rolled off, it just does everything right. Tube rolling with the newer Improved units is a snap where as they can now be accessed from removing four Allen screws from the top plate located on the back of the unit. The first units were a bear to remove the tubes. The Sound Fusion SF-60 suspension kit makes a huge difference in the overall performance and I highly recommend it.
