0 Members and 1 Guest are viewing this topic. Read 9258 times.
Further web searching dug up this reference to dielectric absorption constants See link http://www.clippercontrols.com/info/dielectric_constants.html
How ever the dielectric absorption changes when cotton or silk is formed into textile tubing according to the above reference cotton has a DA constant of 1.3-1.4 and silk is 2.5 to 3.5 none of which changes the fact that the stuff sounds good.
You can always second guess and say something else could have been better.
Having a limited amount of time, I can only do so much.
Anyhow, as far as seeing no difference between signal and ground, thats not how I see it. Ground is defined as a reference, while the positive and negative voltage swings in the signal wire are the music signal.
There are reasons I chose to use a heavier gage ground wire, the functions of the 2 wires are different.
Now, as far as being "close to air" as a dielectric, cotton is less homogenious than teflon, and I'd argue that there is less actual contact between the cotton insulation and the conductor compared to plastic insulation.
The dielectric constant might not be as accurate of a tool as you think for measuring audible changes in insulation material... just like LCR specs won't tell you everything about how an IC or speaker cable will sound.
* each line is free, and not connected or entwined with the other side in any way
unbleached cotton insulator (what a pain to stuff wire into!)
"Ground" is the reference for the circuitry inside the components that's generating, sending, and receiving the signal. But when you're talking about an interconnect or speaker cable, what you're talking about is the propagation of a signal down the cable. And within that realm, i.e. between the two ends of the cable, there is no "ground." What you have is a transverse electromagnetic wave propagating down the cable.QuoteThere are reasons I chose to use a heavier gage ground wire, the functions of the 2 wires are different.Not as far as propagating a signal down the cable is concerned.
Interesting... so the ground wire in the rca jacks, which is combined to a common ground inside the components that it goes to and from, serves some different function when run as an IC or speaker cable?
What if the the signal and ground wire were seperated by a great enough distance that their magnetic fields could no longer interact?
Then what function would the ground serve?
I can gaurantee you the signal will still propagate through the wire.
If what you are saying is true, then the ground plane would need to be paired with the signal all the way through the chain, which it isn't. I will have to disagree that ground changes function while outboard of the chassis, although it does interact with the signal as a result of the cable's geometry.
AdamM, as far as ICs, I have found I like the sound of ICs better when the signal wires do not run parallel with the ground wire.
Would I be correct in assuming that air won't easily permeate Teflon and similar plastics, whereas cotton and silk are comparatively very porous?
I've heard that Teflon is actually permeable to air, on more than one occasion. I think that there are teflon coated wires that are then PVC coated to prevent oxidation. Not sure though.Cheers
Steve your sig: manufacturer is there a link between yr electrical knowledge and yr sig?
If you click on the "Q" under the word manufacturer in Steve's signature, you will understand what it means. The "Q" is a link to his website.
