Hypex Regulators
0 Members and 1 Guest are viewing this topic. Read 1766 times.
samplesj
Hypex Regulators
« on: 17 Sep 2007, 05:27 pm »
Are you carrying the hypex regulators?  I saw a post from a while back that looked like you were and had just sent them back to Hypex because of shortages.  If so, do you know when they may be back in stock?
What is your stock situation on the UCD400HG also?
I had a UCD400AD integrated die.  One of the modules is gone for sure and I'm not sure I trust the other.  I shipped the amp and while it left here working fine, it died within an hour of getting to the destination.  Initially I was just going to gut it for parts, but it turns out I need another higher power amp anyway and that specific chassis doesn't fit my SKA GB300D build well so I'm considering putting it back together.  Your transformer special is probably going to push me over the edge, but I wanted to check about the regulators first.
Kevin Haskins
    • http://www.diycable.com
Re: Hypex Regulators
« Reply #1 on: 18 Sep 2007, 12:19 am »
Yes, I'll be carrying them.   I've got some coming now.   I'd guess 2-3 weeks max.
The UcD400HGs are in stock.
samplesj
« Reply #2 on: 18 Sep 2007, 07:13 pm »
Cool, I went ahead and ordered the amp modules and pieces parts.  I ended up using a lot of the pieces from the original UCD amp for another project so I had to buy pretty much everything except the power supply.
I'll play with them stock for a while and then in a month or two if you've got the regs I'll "upgrade" them.
I loved my UCD/TVC combo for the longest time.  I just wanted an extra bit of warmth.  The UCD/TVC lost out to a Butler hybrid amp originally, but once I added a tube preamp it was really close and I'm not sure I didn't like the UCD better.  I wish I'd upgraded the preamp before the amp and I probably wouldn't have done the amp upgrade at all.
Since Hypex claims the new HG are better than the old AD I'm excited to hear it with and without the regulators.
