Industry Circles
Bryston Limited
Alternate Remote Control SP2
0 Members and 1 Guest are viewing this topic. Read 1428 times.
square
15 Sep 2007, 08:16 pm »
Can anyone suggest an all-in-one type remote control that will work with the SP2? I would like to use custom names for the inputs, and launch a macro based on input selection.
Thanks! Square
brucek
Re: Alternate Remote Control SP2
15 Sep 2007, 09:15 pm »
Since Bryston provides the Pronto codes on their download site, I use a
Philips Pronto
. Works well..
brucek
ec
Reply #2 on:
16 Sep 2007, 12:26 am »
I use the HomeTheatre Master MX-500 (about $100)- a bit more work to program but cheaper than a Pronto. I like the feel of discrete buttons. I also use Macros to turn my system on off as well as switching the video inputs (IScan) as well as the audio (Bryston).
john1970
Reply #3 on:
16 Sep 2007, 12:24 pm »
To whom it may concern,
I use a Logitech Harmony 550 remote with my Bryston BP25 and it works perfectly. I can't comment on the SP2. However, logon to the Logitech Harmony website reveals that it does support the SP2.
Best of luck,
John
square
Reply #4 on:
22 Sep 2007, 11:51 pm »
Thanks for your replies. I purchased a Harmony remote, and the SP2 is in the database. Works great!
Lou
Industry Circles
Bryston Limited
