Bugle PS: What is #4 hardware?
0 Members and 1 Guest are viewing this topic. Read 1795 times.
ShawnMcCann
« on: 15 Sep 2007, 02:06 am »
I'm guessing this is probably standard stuff and easy to find at the hardware store???
riffer
Re: Bugle PS: What is #4 hardware?
« Reply #1 on: 15 Sep 2007, 02:49 am »
I don't what the exact context is, but you may be able to pick up #4 Machine Screws, nuts, and washers at Home Depot or Sears Hardware.  Ratshack may have as well.  Canadian Tire would be an additional place to look in Canada.  Plenty of places on the net as well.
jcg0322
« Reply #2 on: 15 Sep 2007, 03:10 am »
Shawn,
E-mail your address and I will send the exact #4 hardware you need for the bugle at no charge.     [email protected]
best regards,
Jack
ShawnMcCann
« Reply #3 on: 15 Sep 2007, 03:29 am »
Thanks JacK!  Email sent with address.
hagtech
« Reply #4 on: 16 Sep 2007, 05:47 am »
Yes, the SAE 4-40 thread are what I typically use to mount transistors & ICs to heat sinks.  The "#4" is short for 4-40.  That's a number 4 diameter and 40 threads per inch.  SAE is something like the society for automotive engineers.  They standardized nuts and bolts a while back.  You could also probably use an M3 screw.  That's metric for 3mm diameter.
There are actually a lot of standards out there.  Coarse, fine, unified, 80 degree, 100 degree, etc.  Then there are the different materials and ratings.  Military and aircraft grades, commercial, structural.  Who the heck knows what it all means.  I just use stainless steel for all of my nuts and bolts.  It is relatively non-magnetic, reasonably electrically conductive, very strong, and it don't rust.  That's important to me.  I like the machines we build to look like new for eons.  When your grandkids discover it in the attic fifty years from now, not only is it going to look nice, but it's still going to run when they plug it in.
jh
Sarchi
« Reply #5 on: 18 Sep 2007, 05:29 am »
I agree.  But, will they know what to use it for?   :P
hagtech
« Reply #6 on: 18 Sep 2007, 07:02 pm »
To play vinyl.
jh
ShawnMcCann
Re: Bugle PS: Thanks for the hardware!
« Reply #7 on: 20 Sep 2007, 09:56 pm »
Almost forgot:
Thanks to Jack for sending me the #4 hardware!  It arrived safely on Tuesday.
