0 Members and 1 Guest are viewing this topic. Read 14488 times.
What is the "Woofer Widget"?
Kevin,I'm definitely waiting for more! Like when you come out with an MTM open baffle version! I love that Exodus Audio emblem. Maybe making the enclosure taller (and less deeper) so you can fit the emblem below the woofer? Would look cool, but it might screw up your wonderful frequency response. That's a serious motor on the EX6.5 . Much better pics Best,Anand.
If it does half of what you just said it does and does it well (which I'm sure it will), you should sell a TON of those. Good luck. Bryan
Sounds like a beauty in an active speaker arrangement...Bryan
Will the speakers and crossover and box plan be available for those of us that like to build our own cabnets
Do these compare favorably against the 641s, besides a little less low end extension?Is it possible or beneficial to mount the tweeter closer to the woofer, or are the effects negligible?
What is a BBC dip?
KevinHow about vs. your previous 61, a similar sized two-way? I love my 61s. Their bass extension is absolutely unreal for a monitor.-Jim
I've heard a number of Kevin's, I mean Mr. Haskin's, speakers and have always thought that he made intelligent choices when it came to his designs. There are many (some quite well known) that don't, at least in my opinion.Best Regards,TerryO
So essentially you're subtly alter the frequency response in the midrange (?) region to give the speakers a certain characteristic sound? I look at the frequency response graphs and they look very flat, but some of that is due to the drivers and some due to how you voiced the crossover it would appear.I always thought that the goal was perfectly flat on/off-axis response in order to reproduce the recording exactly, which seems nearly impossible given listening room characteristics. Hmm.....
