0 Members and 1 Guest are viewing this topic. Read 48690 times.
All narrow speakers suffer the effect, I think and most designers simply assume it part of the over all design.
The solution using altered drivers or comp networks is not a good solution in a single driver speaker. And all the talk in the world about them and how to deal with it will not fix it. Those pesky laws and the amount of what I'll call "excursion distortion" that any single driver will have can not be overcome.
I would think that backing a speaker up against the front wall only simulates the baffle-step-region-and-below behavior of a bipole; it doesn't accurately simulate the relative intensities and arrival times of the direct versus reverberant energy.
Regarding that rear wall reflection - James M. Kates in his article entitled "A Perceptual Criterion for Loudspeaker Evaluation" (supported by other articles since then) showns that the ear's sensitivity to tonal coloration from a reflection peaks at about 2 milliseconds delay and has tapered off significantly by 5 milliseconds, so if the rear wall reflection arrives much later than that its detrimental effects should be minimal. With dipoles (which I sell), I shoot for a delay of at least 10 milliseconds - which isn't always feasible, in which case I try to diffuse or (as a last resort) absorb the backwave. My understanding is that with enough path-length-related time delay, reflected energy is classified by the ear/brain system as "ambient energy", rather than fusing with and distorting the direct sound.
Even after optimizing the bipole, the big question would still be: Can $X spread among all the drivers and complexity required for a bipolar system sound as good as that same $X spent on a more conventional system? The answer may vary from one person to the next.
I really don't know you of course, but you and your math are essentially world famous... so when I read:"if I have done my math correctly"I didn't know if you grinned to yourself as you typed that or not, but I sure grinned when I read it!
