Onkyo a-9555 (digital amp) vs. Jolida 302b (tubes)
0 Members and 1 Guest are viewing this topic. Read 1035 times.
Mathew_M
« on: 11 Sep 2007, 02:20 pm »
I currently have a Jolida 302b and while I enjoy the tube sound I feel like I'm missing too much of the low end.  I don't currently have the budget to purchase a higher end tube amp so I've been looking for a replacement in the digital realm.  I own a Panasonic XR25 digital receiver which I have been pleased with.  I've read that the Onkyo a-9555 is a much better amp than the Panasonic.  I've also read that the Onkyo has a tube-like sound (though I realize it won't sound exactly the same).  For basically an even trade ($499 retail for the Onkyo vs. $500 used for the Jolida) do you guys think the Onkyo would be a good swap for the Jolida?  I also need a built-in phono section which the Onkyo has.
Anyone compare the two?
Thanks.
ps.  I know some of you will probably say keep the Jolida and mod it but I don't currently have the time or resources to do so.
Turnandcough
Re: Onkyo a-9555 (digital amp) vs. Jolida 302b (tubes)
« Reply #1 on: 11 Sep 2007, 04:07 pm »
I was interested in this amp as an upgrade for my Cambridge 640a V2 but have not found a retailer in my area that has it in stock for a demo. I know a lot of "audiophiles" who would scoff at the idea of trading a tube Jolida for an inexpensive Onkyo but I think that's mostly based on preconceived notions and not actual listening experience. I have yet to hear/read anything negative about the Onkyo except maybe that it lacks a bit of detail. But that could be said about a lot of expensive tube amps also.
musicman06
« Reply #2 on: 13 Sep 2007, 05:52 am »
Pretty much need to try and see for yourself how you like it in your setup. I'd pick the Jolida, but it sounds like the Onkyo may be a better match for you. Personally I use a solid state amp (class A/B Gemstone) and tube DAC. I prefer SS or hybrid (Butler for one) for amps and tubes for pres or sources.
Turnandcough
« Reply #3 on: 13 Sep 2007, 11:45 am »
I agree - the best setup I've owned so far was a tube pre-amp with a pure class "A" amp and electromagnetic speakers. However I know someone who's using a SS integrated as a pre with a tube amp and seems happy...
