which oscilloscope????
0 Members and 1 Guest are viewing this topic. Read 2267 times.
jtwrace
    • TIPP YouTube Channel
« on: 10 Sep 2007, 07:33 pm »
I would like to purchase an oscilloscope for some of the DIY projects as well as seeing the waveform on my AC power.  Which one do you think is a good/resonably priced one?
Thanks-
jon_010101
Re: which oscilloscope????
« Reply #1 on: 11 Sep 2007, 03:33 am »
Just saw this on eBay: 230170576009
Kinda high shipping to offset ridiculous price, however -- maybe ask seller if guarantee non-DOA.
There are a lot of good Tektronix scopes around on ebay, but it often takes some time to find a safe bet.  Even just 20MHz will be overkill (unless you are using tubes that really like to oscillate, like 6C45P), so I wouldn't get anything too crazy/expensive.
« Last Edit: 11 Sep 2007, 05:01 am by jon_010101 »
numa
« Reply #2 on: 11 Sep 2007, 01:59 pm »
Be sure to search ebay for 'misspellings' of oscilliscope, that's how I got my 1ghz tektronix for the $90 opening bid.  Cheers.
Occam
« Reply #3 on: 11 Sep 2007, 02:47 pm »
Naaah....  I can manage to get a lot of analog solid state circuits to oscillate/ring above a MHz. If you're building/debugging analog circuitry, a good analog scope of 20MHz bandwidth might be considered minimal.
If your interest is primarily in looking at your mains, you should consider a line viewer which works with an oscilloscope and provides isolation from the line and facilitates looking at both common and normal mode noise, albeit constrained in bandwidth to 5MHz. I got my OneAC LV-103 off eBay for $30 and they come up reasonably often.
http://www.oneac.com/download/files/917010a.pdf
Imperial
  • Love keeps us in the air, when we ought to fall.
« Reply #4 on: 11 Sep 2007, 03:14 pm »
You have a lot of oscilloscopes today that have USB output, and a software to handle the data.
That could be looked at.
Imperial
ctviggen
« Reply #5 on: 11 Sep 2007, 03:54 pm »
Ooooo...I like that.  It provides more functionality than just a oscilloscope.
jtwrace
« Reply #6 on: 11 Sep 2007, 05:15 pm »
jtwrace
« Reply #7 on: 11 Sep 2007, 11:47 pm »
audioferret
« Reply #8 on: 10 Jan 2008, 08:58 am »
Did you ever try out your scope?  How did you like the stingray?  The brochure lists 250 kHz bandwidth, is that enough?
ctviggen
« Reply #9 on: 10 Jan 2008, 12:07 pm »
That should be plenty for audio signals.  Even for DACs, at 44.1KHz, it shouldn't be bad.
