After the initial 4 triangles (corners) what next?
0 Members and 1 Guest are viewing this topic. Read 5363 times.
jaspal kallar
« on: 10 Sep 2007, 08:36 am »
I was wondering if you upgrade a bit at a time after getting the initial 4 triangles (corners) what is the best way forward. For example, say I only have enough money for 2/3 rectangles. Would I do the front wall (i.e the one behind the speakers) or do I do the back wall or the side 2 walls?
I understand that it's of course room dependent (mine being around 15'x13', speakers on the long wall).
My aim is to get the 4 triangles and then a bit later 3 rectangles. Of course the aim is to get to the full suggested set, but that's not always possible money wise in one swoop. Maybe adding bitwise one appreciates each change more.
Cheers
    jaspal
8thnerve
Re: After the initial 4 triangles (corners) what next?
« Reply #1 on: 12 Sep 2007, 05:03 pm »
It depends on your room where you'll get the best results, so send along pictures and I can let you know how to proceed.
You will certainly notice improvements along the way, and yeah, sometimes it can be fun to go piece by piece!
