Array of Desire...
0 Members and 1 Guest are viewing this topic. Read 8509 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Array of Desire...
« on: 7 Sep 2007, 11:33 pm »
... eight Fountek Pro5i ribbons and eight Scan-Speak Revelator woofers per side plus sub pictures coming soon  8)
« Last Edit: 8 Sep 2007, 02:12 am by Rick Craig »
gme109
Re: Array of Desire...
« Reply #1 on: 8 Sep 2007, 05:41 am »
I don't know if those are going to fit in the overhead compartment :scratch: Sure wish you could bring em to the RMAF.
musicman06
« Reply #2 on: 8 Sep 2007, 09:31 am »
 :drool:
klh
« Reply #3 on: 9 Sep 2007, 05:13 am »
I echo your thoughts musicman... then again at this point I'm dreaming and definitely not thinking :D)
Midnite Mick
« Reply #4 on: 9 Sep 2007, 05:21 am »
Wow...those are some nice sounding and expensive parts.  I could only imagine.
Mike
FredT300B
« Reply #5 on: 9 Sep 2007, 08:59 am »
Wow...those are some nice sounding and expensive parts...
Mike
Rick is also working on a less pricey line array which he plans to call "Array of Hope" for the poor and downtrodden.  :lol:
Rick Craig
  • Selah Audio
« Reply #6 on: 10 Sep 2007, 01:43 am »
I can check two bags, right?  :lol:
Rick Craig
  • Selah Audio
« Reply #7 on: 10 Sep 2007, 01:55 am »
Mike
Now that was really funny  :lol: :lol: :lol:
Seriously, it's going to be a interesting project. I'm also buying a large quantity of drivers if anyone would like to get a great deal on a kit  :wink:
Bill Baker
    • Musica Bella Audio
« Reply #8 on: 10 Sep 2007, 02:26 am »
 If this is (and I believe it is) the same speaker one of my customers just purchased, they are a high effeciency design as well. I think he mentioned 95dB/96dB :scratch: He is also getting the sub towers. Nice work Rick!
Midnite Mick
« Reply #9 on: 10 Sep 2007, 02:41 am »
Hard to imagine you would still need any subs with that.
Rick Craig
  • Selah Audio
« Reply #10 on: 10 Sep 2007, 03:41 pm »
Your amps will coast with this load  :)
Rick Craig
  • Selah Audio
« Reply #11 on: 10 Sep 2007, 04:46 pm »
This is a sealed box so it's -3db @ 55hz. That makes it ideal for use with a subwoofer. We could build a larger ported cabinet to extend the bass to -3db @ 45hz; however, most of our customers want bottom octave extension and only subwoofers will do that unless you apply a large amount of active EQ. This is my reference now, the best array that I have designed.
« Last Edit: 11 Sep 2007, 05:42 pm by Rick Craig »
Brucemck
« Reply #12 on: 11 Sep 2007, 05:44 pm »
Rick, how would you characterize the differences and tradeoffs between the Arrays of Desire and the IncrediArrays?
Rick Craig
  • Selah Audio
« Reply #13 on: 12 Sep 2007, 12:22 am »
The Incredarray has built-in dual 12" subs but the Pro5 array is designed to work with external subwoofers. This particular version is also wired for a high impedance because the owner is going to use an OTL amp. Tonally they are different due to the different woofers plus the Pro5 ribbon allows a lower crossover point. The 7" woofers can cross in the 55-60hz range versus 70-80hz for the 5" woofers. I've also voiced the Pro5 array differently and it shares a similar voicing to the Accuarray that you have and the Revarray.
 The Pro5i has more "body" in the lower treble, more open sounding in that area, but a slightly softer top end response. Due to my previous experience using the Pro5 in a center channel I had expected that and it makes sense given that the ribbon is longer and wider. Off-axis the Pro5 is still exceptional though and with the element being .6" wide it has better horizontal dispersion than a 1" dome or the planar drivers from BG and others.
bubba67
« Reply #14 on: 14 Sep 2007, 04:12 am »
Rick,
Any further info about timeframe for availability and prices on your new "ultimate" array designs?
Bubba67
Rick Craig
  • Selah Audio
« Reply #15 on: 14 Sep 2007, 04:33 pm »
Rick,
Bubba67
$13-16K is going to be the approximate price range. All three are available for order right now.
Val
« Reply #16 on: 15 Sep 2007, 03:01 pm »
Rick, why no arrays with 9 x 5" Revelators? How would one compare to this?
Rick Craig
  • Selah Audio
« Reply #17 on: 15 Sep 2007, 04:46 pm »
That would be an excellent combination. It's just a matter of tradeoffs and what your goals and preferences are. The 5" drivers typically cross higher to subs but have wider horizontal dispersion. The 7" drivers of course move more air and have greater excursion capability (though the excursion is rarely taxed from using multiple drivers). We also consider the sensitivity and interior volume needed for the design.
In listening I  find that the differences of my current arrays are subtle but the AOD design takes the performance to a new level.
« Last Edit: 15 Sep 2007, 05:09 pm by Rick Craig »
bubba67
« Reply #18 on: 21 Sep 2007, 09:46 pm »
Rick, I saw on your website the Accurarray and Revarray - do you have any further written info about these speakers - do they come with additional subs? pricing? options? etc.
Bubba67
Rick Craig
  • Selah Audio
« Reply #19 on: 22 Sep 2007, 04:26 pm »
Bubba67
I expect the price will be around $16,000/pair. Deluxe crossovers,grills, standard veneers, and shipping included. You'll need to add subwoofers and the Linanite is a good match.
This particular pair is configured for a higher impedance (minimum 10 ohms, average 13 ohms) to suit the owner's OTL amp. I can also design it for a 4-ohm load if desired. Sensitivity is 95db or 98db depending on which configuration you choose.
