Splitting Cornet2 output
0 Members and 1 Guest are viewing this topic. Read 1204 times.
machine
« on: 5 Sep 2007, 07:33 pm »
Can I use Y adapters and split the output?
I think this should be Ok, just want to verify.
How far of run can you do with decent RCA cables?
Might move turntable to back of room to be closer to computer
How about the Picolo?
Want to feed a AD converter to record some albums.
« Last Edit: 6 Sep 2007, 01:39 pm by machine »
hagtech
Re: Splitting Cornet2 output
« Reply #1 on: 6 Sep 2007, 04:52 pm »
Sure.
Both CORNET2 and PICCOLO have buffered outputs, which allow them to drive long cables.  Only reason to move turntable is so that you don't have to edit out all that dead time.
jh
machine
« Reply #2 on: 6 Sep 2007, 05:03 pm »
Also dealing with Hum/ground loop issues so moving a few things might help...
The cable run from the Cornet2 to preamp would be about 25-30', and problems with this?
hagtech
« Reply #3 on: 6 Sep 2007, 10:02 pm »
No problems.
jh
