Front Baffle Material-for wood/acoustics specialists
0 Members and 1 Guest are viewing this topic. Read 1489 times.
konut
There is currently a manufacture that CNCs a solid wood front baffle. 5 wood choices are available. From a technical standpoint will the choice of wood affect the acoustic properties of the cabinet,as far as resonance is concered, or the propagation charactaristics of the tweeter? I ask this as different woods have different hardnesses and was wondering if these differences will have any measurable effect on the sound, apart from the visual differences of different woods.
ooheadsoo
Re: Front Baffle Material-for wood/acoustics specialists
« Reply #1 on: 4 Sep 2007, 10:44 pm »
I think the wood is 3 inches thick, well treated and damped.  What did the manufacturer say when you asked them?
konut
« Reply #2 on: 4 Sep 2007, 11:01 pm »
I'm waiting for his reply. Just thought I'd get other input and maybe some pertinent links.
drmike
« Reply #3 on: 6 Sep 2007, 07:22 pm »
is there a web site for this cnc baffle person?
thanks
konut
« Reply #4 on: 6 Sep 2007, 07:39 pm »
Here is the website.  http://www.4sptech.com/
Here is a thread with good pixs of the baffle.  http://www.audiocircle.com/index.php?topic=43286.0
