pre-amp Audiotechnica AT-PEQ3
0 Members and 1 Guest are viewing this topic. Read 1005 times.
zolono
« on: 4 Sep 2007, 02:29 pm »
http://cgi.ebay.com/NEW-audio-technica-Phono-Equalizer-AT-PEQ3_W0QQitemZ300147889970QQcmdZViewItem?hash=item300147889970&_trksid=p3286.c50.m20.l1116
for ММ Audio technica AT-150MLX -enought good pre-amp?
I need digitize my vinyl discs on simple turntable Project Debut 2
Toka
Re: pre-amp Audiotechnica AT-PEQ3
« Reply #1 on: 4 Sep 2007, 03:18 pm »
Looks like it'll work just fine.
zolono
« Reply #2 on: 4 Sep 2007, 05:33 pm »
Thank you!
In technical description I don't understand nothing  :oops:....
people say "too small money for good pre-amp"  :roll: -is it true?
Toka
« Reply #3 on: 4 Sep 2007, 05:53 pm »
It is impossible to say how much money you need to spend to get something 'good'...looking at the specs for that preamp, I see a S/N ratio of 80dB, which is better than some units that cost 3 times as much, and that is one of the more important things to look for. Plus, it is designed by the same company that made the cartridge you are using, so they likely used them together when they were designing it. For what you want to do, it will get the job done!  8)
zolono
« Reply #4 on: 4 Sep 2007, 06:30 pm »
well,soon i'll buy good sound card and begin to check quality of my future MP3  :drool:
