Bi-wiring from by 4BST
0 Members and 1 Guest are viewing this topic. Read 2321 times.
Helvellyn
« on: 4 Sep 2007, 08:02 am »
Hi everyone - newbie here with my first question.
I went from an Audiolab 8000P, where I bi-wired my Audio Vector 5's, to my Bryston 4BST(Pro). The trouble is, the Bryston only has one set of speaker posts. Is it worth bi-wiring onto the one set of posts on the Bryston or should I stick to one cable run?
Thanks in anticipation.
Simon
Helvellyn
Re: Bi-wiring from by 4BST
« Reply #1 on: 4 Sep 2007, 08:50 am »
A further possibility from my post above is that I could tri-wire, as the AV's a have three sets of binding posts. With respect to the above post, is there any mileage in tri-wiring back to the one set of posts on the Bryston?
brucek
« Reply #2 on: 4 Sep 2007, 11:37 am »
My understanding is that bi-wiring is always accomplished from a single set of posts on the power amp, connected with appropriately split speaker cables to dual sets of posts on the speaker. Why do you feel the Bryston is any different?
brucek
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 4 Sep 2007, 12:15 pm »
Hi All,
One option is to use a Spade and an Expandable Banana at the speaker outputs on 2 sets of wires.
james
Helvellyn
« Reply #4 on: 4 Sep 2007, 02:38 pm »
brucek
Bruce - that might be true in the majority of cases but not so with the Audiolab, which had four posts per channel - which is why I asked. I'm sure they were linked inside the box and were presented that way to make bi-wiring an easier option.
Helvellyn
« Reply #5 on: 5 Sep 2007, 07:30 am »
Hi All,
james
Can anyone, James or other, recommend such items, with possible links? Bearing in mind I'm from the UK. Thanks
rabpaul
« Reply #6 on: 6 Sep 2007, 07:39 am »
Hi All,
james
The speaker outputs accept spades, bare and bananas so I this is what I am doing too. Spades for speakers, bananas for subs. Unless the 4BST speaker outputs are different from 4BSST this will work for you too.
