Jolida JD-100 with level 2 mods SOLD
0 Members and 1 Guest are viewing this topic. Read 1258 times.
Jjwaudionut
« on: 1 Sep 2007, 05:16 pm »
Jolida JD-100 in BLACK with level 2 modification by Parts Connexion. $950 ($1850 new). You get the level 2 upgrade player for the price of an unmodified new one. This unit is 18 months old in perfect condition. Gold pin EH tubes (part of level 2 upgrade) have been replaced with JJ 12AX7 tubes, but unit is otherwise the same as sold by Underwood HiFi. Purchased from Underwood in April 2006. All original packaging and documentation. Sweet sounding CD player ready to add a touch of tube magic to any solid state amplification chain. Read the reviews, there are plenty of great ones out there.
Level 2 mods include: • 4 sheets of SoundCoat dampening material applied to internal chassis • 4 EAR compliant Sorbothane isolation feet • 1 pr. Vampire RCA jacks (OFC Copper body, gold-plated) • 2 ft. DH Labs pure silver, Teflon dielectric, output wire • 8 Ultra-fast, soft recovery Hexfred and Fred power supply diodes • 7 Black Gate Standard, N and C grade electrolytic capacitors around the coupling caps and power supply • 4 Black Gate 150uf 350V VK grade electrolytic capacitors in the high voltage power supply reservoir • Audio Note Tantalum 0.5-watt signal path resistors • 4 Multicap PPMFX grade, metallized polypropylene capacitors in the signal path • 4 Multicap PPFXS grade, polypropylene film and tin foil coupling capacitors • 4 Rel-Cap TFT grade, 0.01uf Teflon film and tin foil, bypass capacitors for the main coupling caps • TRT Wonder Solder used throughout
« Last Edit: 20 Sep 2007, 02:13 am by Jjwaudionut »
