Home-made rumble/noise detector
0 Members and 1 Guest are viewing this topic. Read 1708 times.
Wayner
« on: 1 Sep 2007, 01:08 pm »
If you have a microphone and some place to plug it in and a pair of headphones, you have the makings for a great rumble/noise detector for finding and eliminating the source of noise on your table. I taped a 6" steel ruler to the side of my microphone with about 4 1/2" of the ruler extending past the front of the microphone from my mini-disc recorder. I put on the headphones and put the recorder in record mode. With the volume turned up I touched various points on the table with the free end of the 6" ruler. The noise I heard was incredable! The motor mounts made gobs of noise but when I move to the subchassis, it was reduced to a faint trickle. I then proceded to other parts of the table. I put a record on and could hear the music fairly well just from the stylus in the groove. I have found a source of noise I'm trying to eliminate now.
W
murillo
Re: Home-made rumble/noise detector
« Reply #1 on: 6 Sep 2007, 05:21 pm »
Good info Weiner  :thumb:, another good aproach is to use an medical stethoscope if you have some family member or freind that is a doctor.
murillo
« Reply #2 on: 6 Sep 2007, 07:08 pm »
 aa sorry WAYNER!
