Piccolo Question!
0 Members and 1 Guest are viewing this topic. Read 1329 times.
amandarae
Piccolo Question!
« on: 29 Aug 2007, 08:19 pm »
Is C1L and C1R (100uF) value critical on the Piccolo?  Can i experiment with a 1 uf caps on it?  i have some jensen PIO and Hovland Poly that I want to try if possible.
regards,
Abe
« Last Edit: 30 Aug 2007, 03:49 am by amandarae »
hagtech
Re: Piccolo Question!
« Reply #1 on: 30 Aug 2007, 05:21 pm »
Yes, this is a critical signal coupling cap (100nF, not uF).  Use the best that will fit.
jh
amandarae
« Reply #2 on: 30 Aug 2007, 06:18 pm »
jh
Umm yeah, I stand corrected.  That is .1uF.  Thanks Jim!
regards,
Abe
