WTB-Multichannel Amp
0 Members and 1 Guest are viewing this topic. Read 2468 times.
launche
  • ...on being an audiophile...no.
« on: 29 Aug 2007, 04:06 am »
Looking for a multichannel amp with at least 100/200 watts into 8/4ohms with true balanced connections.
respond here or PM me if you have something of interest.
John Casler
Re: WTB-Multichannel Amp
« Reply #1 on: 29 Aug 2007, 04:23 am »
ATI is supposed to be "truly" balanced at a good perfromance and price.
zybar
« Reply #2 on: 29 Aug 2007, 07:59 am »
I am not sure about whether some ATI amps are truly balanced or not, but I can say that my single ended 1506 is a beast and quite impressive.
George
launche
« Reply #3 on: 29 Aug 2007, 12:56 pm »
Thanks gentlemen,
Yes, I looked a little and some ATI models are balanced and some are not.
ATI is one amp I am strongly considering, I looked at the 1506 in particular but it is single ended, which I could do it need be.
Zybar, how have you used the the 1506 (HT and/or 2 channel)?
I would use the intended amp both ways. Although I am more concerned about its 2 channel performance.
Zybar, how does it compare more or less to the other amps you've had in house, some of which I've heard.
zybar
« Reply #4 on: 29 Aug 2007, 02:20 pm »
Thanks gentlemen,
I will be using the 1506 to drive three Salk SongTowers as the L/C/R channels of my dedicated HT.
However, I have only listened to the 1506 in stereo at this point.
Let me get a little more time with it before I give any serious comments.
George
Daygloworange
  • www.customconcepts.ca
« Reply #5 on: 29 Aug 2007, 02:53 pm »
Thanks gentlemen,
launche,
I've owned an ATI 1202 for 2 years now and like it a lot. So much so that I just bought a second one, so that I can vertically bi-amp. A real neat feature the amp has are input gain pots on the back of the amp that allow you to adjust gain so you can balance between channels, or in the case of vertical bi-amping, I can adjust the output of the woofer section compared to the upper frequency section of my speakers, and fine tune for in room bass balance.
We had my ATI in the TAAS Amp Comparo earlier this year along in a blind test with a bunch of amps, and it got a lot of very positive comments. After the comparo I walked away feeling even better about the amp. I find it to be quite neutral, with a good, tight, dynamic, punchy sound.
And it is dead quiet.
The TAAS Amp Comparo:
Cheers
launche
« Reply #6 on: 29 Aug 2007, 05:07 pm »
Thanks for the info. Dayglo.
Was there a thread associated with that event?
I'd be interested in reading it, there were some nice amps at that event.
Before getting your second ATI did you bi-amp with another brand amp and what were the results.
Daygloworange
« Reply #7 on: 29 Aug 2007, 06:00 pm »
Yeah, I tried  horizontal bi-amping just for kicks using a Trends TA 10.1 on the MTM section of my speakers, and my ATI on the woofer section and loved the ability to control the woofer output via the adjustable gain pots. It really helps with room gain effects on low frequencies.
There are a number of posts about out TAAS Amp Comparo in the TAAS Circle here on AC. Look around the TAAS circle for other offshoot threads. Here is the main thread and the summary of how we conducted the Comparo. It was a lot of fun.
http://www.audiocircle.com/index.php?topic=34570.90
Cheers
John Casler
« Reply #8 on: 29 Aug 2007, 08:08 pm »
Launche,
Did I miss your "budget" for said amp?
launche
« Reply #9 on: 29 Aug 2007, 11:57 pm »
Up to 2k is the budget.
Levi
« Reply #10 on: 30 Aug 2007, 03:42 am »
$2,000 is a good budget for a good used system.  What type of preamp do you have?  Very important for synergy.
launche
« Reply #11 on: 30 Aug 2007, 04:12 am »
EE Minimax
and
Prometheus TVC
Levi
« Reply #12 on: 30 Aug 2007, 05:14 am »
Hmmm...this is going to be a tough one.  Are you going to use it for video or music?
launche
« Reply #13 on: 30 Aug 2007, 05:25 am »
Levi, you're starting the scare me  :)
Amp will be used for both purposes (eventually).
Also, I may replace the Minimax.
Levi
« Reply #14 on: 30 Aug 2007, 05:49 am »
Well you want to match the amp to the preamp so you have synergy for best sound.
I would probably try Classe audio CAV-180.  It sounds really good for both music and movies + it has a separate balanced circuit.
