0 Members and 1 Guest are viewing this topic. Read 2731 times.
What is the difference using a relatively smaller R1/R2 value resistor vs relatively larger value resistors? Is there a capacitance or inductance difference large to small, or does it just not matter at all? My guess is there is probably an optimal way of doing this, because as we all know, everything effects everything else.
...You could also use a step-down transformer which would give you the attenuation you need, but without increasing output impedance or reducing the load impedance seen by the source component.se
Using a higher R1/R2 presents the source component with an easier load to drive, but at the expense of a significantly higher output impedance which can have implications for increased noise as well as high frequency rolloff due to cable capacitance.Using a smaller R1/R2 doesn't increase the output impedance as much, but the source component will have a more difficult load to drive which can increase distortion.
Would this perhaps be preferable, as the step-down transformer would present a lower output impedance (square of turns ratio, etc)?
Again, if you put the pad (as you would with the transformer) inside, or at the load, you have a much higher range of resistance loading to play with. Without having to worry about HF loss.......noise pickup........current loading........I kinda think he had this sort of answer in mind.........but I could be wrong.
I used Edcor coils for that, mostly because they were inexpensive. I do believe that using a better quality coil would result in better sound, but Jensens are expensive, for sure, and that's not what I was looking for.
The higher quality resistors I used for this experiment worked wonderfully.
Thanks for all your help guys,
