Bryston 9b SST & SP 1.7 Speaker pairing
0 Members and 1 Guest are viewing this topic. Read 2761 times.
dn54168
« on: 28 Aug 2007, 12:31 am »
Hello Guys,
This is my first post.
I know this is a very subjective poll and there are many variables involved , but I was just wondering, when using Bryston 9b SST & Sp 1.7 which speaker sounded the best to you?  Or In your opinion, which Speaker (Manufacture / Model ) should pair up best with Bryston 9b SST? :scratch:
jethro
Re: Bryston 9b SST & SP 1.7 Speaker pairing
« Reply #1 on: 20 Sep 2007, 09:18 pm »
It's a bit late, but Welcome.
I'd have to recommend PMC speakers. I'm not sure which model would be appropriate for
you since it depends on how loud you listen. You probably won't get the best out of the IB-1 or IB-2
with the 9B-SST unless you bi-amp. A lot of people recommend B&W speakers. I have a
feeling that Proac would match well but I don't know which model I was listening to. I think
James Tanner has done some recent listening tests with magnepan and quad. I personally
like a lot of bass so that limits my preferences.
HTH and sorry I missed your message, Steve
Burke
« Reply #2 on: 21 Sep 2007, 01:59 am »
In the end, it is your ears that must  be pleased, so I recommend seeking out a few different brands to mate up with the Brystons and give them a listen to decide what you like best with the music you enjoy.
Nevertheless, here are a few observations and suggestions:
The Bryston SP1.7 will be wonderful regardless of which speakers you choose. The Bryston 9B SST is a great sounding amp and I love Magnepan speakers (that's the brand that keeps me listening at home night after night), but having tried a 9B in my own system for an extended "test drive", I found that if you want dramatic dynamic range (i.e., appreciable difference in volume between loud and soft passages) and maximum musical detail, you either need a more powerful Bryston amp (4b on up) or more efficient speakers than the Maggies.
If the PMC line is too difficult to get a hold of where you are for an audition and/or purchase, the Bryston 9B SST will do wonders for some more readily available (albeit not nearly as refined) speakers such as top-end Definitive Technology speakers (if that isn't too much of an oxymoron) :>) Actually Def Techs are not as bad as some skeptics say though certainly not as good as their ads would have us believe, either.
The 9B would also do well with Paradigms or (I hate to mention, since I don't really like them) Klipsch which basically only need an amp playing somewhere in the same county to sound loud, they're so efficient. (That's an exaggeration, but they don't need much power to play loudly, and the 9B would have more than enough reserve to max them out.)
Of course there are other brands such as JM Lab, KEF, NHT, Linn or Vandersteen that would be more in the audiophile realm than Def Tech, Paradigm, or that other one which starts with "K". But while they might also be less readily available for demo and purchase, they would certainly be worth seeking out for a listen.
Burke
Phil A
« Reply #3 on: 21 Sep 2007, 02:35 am »
My friend uses Thiel 2.4s with the 9BSST/SP 1.7 combo in an average sized room (and they work fine and the Thiels are about avg. efficiency).  I have another firend who uses Vienna Acoustics speakers with the same combo in a bit bigger room.
Levi
« Reply #4 on: 21 Sep 2007, 02:43 am »
Welcome!
I currently have a 9B-SST & SP 1.7.  I am using Sonus Faber Grand Piano Home.  They sounded pretty good!
-Cheers,
Levi
Hello Guys,
mariusconst
« Reply #5 on: 14 Jan 2008, 07:45 pm »
Hi,
I am using B&W 803 with 9B-SST and SP1.7.
Marius
BMU (Bryston Maggie User)
« Reply #6 on: 15 Jan 2008, 01:46 am »
Hi
I'm using a Squeezebox 3 - SP 1.7 - 9BST - Magnepan 1.6QR's.  I use 4 of the 5 9B channels to bi-amp the Maggies.  I'm quite happy with this setup.
Previously had a Paradigm Studio reference hooked up to the Bryston electronics.  Nothing wrong but it was not a planar type sound.  Now the Paradigms are in the TV / theatre room.
HTH
rcjordin
« Reply #7 on: 22 Jan 2008, 10:18 pm »
Would the Focal Be 1000 line match this combination as well?
Robert
Sugar Land, TX
