0 Members and 1 Guest are viewing this topic. Read 2072 times.
Because a transformer is an impedance transformation device. In order for the plate to see the right impedance (it is designed to work into), you have to match/"select" the right tap.
The actual impedance of the speaker varies considerably with the frequency applied, most of which has to do with the speaker crossover.
