PICCOLO Resistor Loading Equation
0 Members and 1 Guest are viewing this topic. Read 1585 times.
hagtech
« on: 17 Aug 2007, 07:54 pm »
For those of you who would like a custom range of resistor values for cartridge loading, I've come up with an equation to help you determine the intermediate values.  It uses a geometric sequence.  That is, a constant multiplier between values.  The formula is
k = (r5/r0)^0.2;
or you divide the final value by the initial value, and then raise to the power of 1/5th.  For example, if you want a range from 20 ohms to 200 ohms, then we get k = 1.585.  We use this as
r(n+1) = r(n) * k;
or to get the second value, multiply 20 * 1.585.  The sequence (for this example) is thus
20
31.70
50.24
79.62
126.2
200
And the closest 1% resistor values would be
20R0
31R6
49R9
78R7 or 80R6
127
200
jh
ecir38
Re: PICCOLO Resistor Loading Equation
« Reply #1 on: 17 Aug 2007, 08:08 pm »
Awesome, thanks Jim.
hagtech
« Reply #2 on: 17 Aug 2007, 09:19 pm »
Here's another way to do it.  You'll notice that when I plot the above example you get a straight line with a logarithmic Y axis.
So you can set any two endpoints, draw a straight line, and the intermediate values can be read directly from the graph.  You really don't have to be that accurate, the only reason I specify 1% resistors is that they are metal film types and sound good with very low added noise.
jh
tubesforever
« Reply #3 on: 25 Aug 2007, 09:31 pm »
Jim I feel dumb asking this question, but what value resistors go in the R2 right and left slots?  I cannot find anything at all in the directions.
Are these dependent on the resistor values selected for the R1 right and left?
ecir38
« Reply #4 on: 25 Aug 2007, 09:36 pm »
See the second the last page in the manual or for a larger printable version the third pic i sent you.
hagtech
« Reply #5 on: 26 Aug 2007, 06:16 pm »
Best to use the guide in the manual which states values for each resistor, rather than their reference designators.  The schematic might be a little confusing (I drew it that way on purpose to make the machine harder to counterfeight).
jh
