Bryston 4B left channel hum
0 Members and 1 Guest are viewing this topic. Read 2334 times.
zenblaster
« on: 16 Aug 2007, 11:08 pm »
I just got my first Bryston- a gorgeous 4B from 1977 that looks right out of the box. It was just at Bryston a few months ago so I am assuming everything is ok. when I power it up I am getting a  pretty good hum from one channel. what's the process to find the problem, thanks
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston 4B left channel hum
« Reply #1 on: 17 Aug 2007, 12:35 am »
Reverse the inputs and see if the hum stays on the same side.
james
zenblaster
« Reply #2 on: 17 Aug 2007, 10:30 am »
I switched inputs and the hum stayed on the same side. If I switch the toggle to stereo (as opposed to mono) the hum is in both speakers.
By the way- this amp looks like it just came out of the box in 1977,  the original box even looks new!
thanks,
Bernie
« Reply #3 on: 17 Aug 2007, 10:45 am »
If you disconnect the inputs and have the speakers connected does the amp hum?
james
zenblaster
« Reply #4 on: 17 Aug 2007, 07:31 pm »
no hum with amp on and speakers connected
« Reply #5 on: 17 Aug 2007, 07:41 pm »
Ok it sounds like it might be a bad ground on the input stage of the amplifier or a bad cable feeding that channel - please give Bryston Service a call.
james
zenblaster
« Reply #6 on: 17 Aug 2007, 08:17 pm »
I  found the hum- when I disconnected the cable input from my pre the hum stopped. Now I have to  properly ground the cable and I should be OK
Thanks for the quick response James
