Total Members Voted: 12
Voting closed: 11 Sep 2003, 12:46 pm
0 Members and 1 Guest are viewing this topic. Read 3820 times.
I have a Teres that does NOT have a return, although the motor will shut off after 45 minutes.I have a 30 year old or so Sansui that WAS higher end at the time, but is not know. It does not have auto return, but it does have an auto lift/auto off. You can set the auto lift/auto off to work or not if you think it effects the sound.
I have two turntables in use, although neither of them are considered hi-end. One is a Studer Revox, which is "auto-return/auto-off". The other is a Basis, which is "auto-nothing".So, my two votes would cancel each other out.Kevin
this is what i use (well, actually, i use a similar ~25-yr-old thorens iteration) to lift off the tonearm at the end of the record w/my 100% manual oracle delphi:http://www.expressimoaudio.com/lift/lift.htmldoug s.
What exactly IS it that triggers the lifting bar??
