Nice mid driver for OB: Monacor SPH-176
0 Members and 1 Guest are viewing this topic. Read 5031 times.
Rudolf
« on: 13 Aug 2007, 08:06 pm »
Sorry, if this is only of interest for my fellow Europeans :roll: but
I want to share my experience with a very interesting and affordable midwoofer for OB use: the Monacor SPH 176: http://www.monacor.com/int/en/produktseite_suche.php?artid=4084&spr=EN&typ=full
Unusual for a stamped metal basket it features a rear vented spider and venting holes in the coil former. So no vented pole piece is necessary.
I found some measurements, which are independent from the official ones and they showed a shallow dip at 300-2000 Hz.
Simulating this driver at the top of a 30-40 cm wide OB, EDGE showed a shallow peak (thin red lines) just in the same range as the dip (other lines).
I put the real driver in a real 40 cm wide OB (Don´t mind the tweeter in front of the SPH-176. I took it off for measurements)
and applied an active 230 Hz HP and a passive 2.7 kHz LP filter. 30° off axis I got this measurement:
Without the LP filter and on axis SPL looks like this:
Of special interest is the added measurement of the output to the rear (red line). Regarding the stamped frame both front and rear output are very well in line up to 2 kHz.
While I am still struggling with that coax tweeter alignment I much appreciate the very natural rendition of the SPH from 200-2500 Hz.
Rudolf
BTW: If you fill the back side of the hollow U-shaped rim of the driver with hot-melt adhesive (as I did), the distortion peak of the original driver at 3-4 kHz is significantly reduced (compare red and blue peak in the first diagram).
Luigi
  • Busa doing the business
Re: Nice mid driver for OB: Monacor SPH-176
« Reply #1 on: 13 Aug 2007, 10:25 pm »
Admiring your OB subwoofer in the image of the Monacor.
Can you tell us a bit about this? It looks like it is in an H-frame. What's the driver? And what drives it?
opnly bafld
« Reply #2 on: 14 Aug 2007, 01:21 am »
http://www.audiocircle.com/index.php?topic=39094.0
