0 Members and 1 Guest are viewing this topic. Read 16288 times.
Aren't the resonances you see based solely on the depth of the cavity?
It's interesting that the triangular shaped cavity eliminates the sharp resonances. This indicates that the shape of our baffle foldings can be effective in solving resonance problems.
Also, I find the Fpeak at 300hz perplexing. I expect it to be up well above 400hz. The only explanation is the floor effectively increasing "D".
Can you put the cab up on a pedestal to simulate freespace and do another nearfield measurement. I've been thinking that the floor benefit was primarily as boundary reinforcement, but if it also lowers Fequal, that is very good news in terms of bass response.
I hope Florian sees these graphs. They clearly show how helpless we are in trying to fight against dipole bass cancellation without using EQ.
QuoteAlso, I find the Fpeak at 300hz perplexing. I expect it to be up well above 400hz. The only explanation is the floor effectively increasing "D". It is known from BR tubes and TMLs that the acoustic length of those "cavities" reaches well beyond the physical length. Somewhat surprisingly this effect is bigger for wide openings than for small ones AFAIK. Added boundary planes will extend that acoustic length even more.
I already can assure you that the efficiency of the mini would be almost 10 dB below the H-frame.
This does, however, get me back to a question I may have asked poorly before. What draws you to build the small H's when a U essentially half the size delivers the same bass performance?
Regarding the shape of your mini, if we can come up with what the real world effective path length is for such a shape, then we'd be well on our way to designing resonance free U-type shapes (ie no damping needed).
Quote from: JohninCR on 7 Apr 2007, 01:26 pmRegarding the shape of your mini, if we can come up with what the real world effective path length is for such a shape, then we'd be well on our way to designing resonance free U-type shapes (ie no damping needed).Enter Visaton NoBox . John, I know you already dismissed that one as a "off the cuff design", but I reckon sloped wings do have some appeal: Larger wings around the woofer, smaller around the FR, added stability...
For a first shot, the NoBox may be the way to go, since it can easily be tweaked. If in fact, the small cavity behind the main driver on the Quasar is a problem, it would be difficult to correct afterward. but big radiused roundovers would be a piece of cake. If someone donated the wood, I'd build something similar in a lot of respects to the Quasar. I just haven't been willing to burn up that much material while I'm still learning and trying new things.
