Review: PS Audio Digital Link III DAC
0 Members and 1 Guest are viewing this topic. Read 4681 times.
Jon L
« on: 10 Aug 2007, 10:32 pm »
For those interested, I posted a review of the PS Audio DLIII DAC here:
http://www.head-fi.org/forums/showthread.php?t=254652
kyrill
Re: Review: PS Audio Digital Link III DAC
« Reply #1 on: 9 Sep 2007, 11:47 am »
thx for sharing, nice photoos,,
It would be possible to omit the S/pdif link and replace it by USB out from the PC when you use the pc. Then you need an USB to I2S converter.  There are several on the net YEO, the Monica DAC designer has a nice one as well as Doede Douma. A local or maybe yourself technician can build the ( mostly little pcb USB /I2S converter inside the DAC and connect it to the I2S "node" of the internal DAC board
probably not really helpful with AADac + Jisco
Spdif is an elephant form the past :D like now hdmi is
« Last Edit: 9 Sep 2007, 12:51 pm by kyrill »
