0 Members and 1 Guest are viewing this topic. Read 3206 times.
I'm still not convinced an audiophile grade speaker makes a good HT speaker, which will be my predominant reason for buying them. Perhaps I need to demo more.Any ways, how wide of a soundstage do you get with the SongTowers? ie, how is off-axis performance?
Thanks for the reply Dale. The FR at 60 degrees looks excellent. I don't know of any manufacturers that provide that data so it's hard to compare. On a somewhat off-topic note, is there a picture of one of your crossovers somewhere?Forgive my newbness but why go with a custom crossover over a mass-produced one?
Quote from: Magnus_CA on 10 Aug 2007, 02:27 amI'm still not convinced an audiophile grade speaker makes a good HT speaker, which will be my predominant reason for buying them. Perhaps I need to demo more.Any ways, how wide of a soundstage do you get with the SongTowers? ie, how is off-axis performance?The off-axis performance is shown at http://www.audiocircle.com/index.php?topic=43364.0 That's about as good as can be achieved given the laws of physics. Whether that translates into a "wide soundstage" is still open to discussion. Everyone seems to have a pet theory concerning what contributes to soundtage width, depth, specificity. Choose the one you like: off-axis performance, baffle width, radiation pattern, phase tracking (not to be confused with a transient perfect crossover), crossover order, ability to pass a square wave (that's where transient perfection enters), and, of course, sunspot activity. This is not a perfect science. And soundstaging doesn't matter unless the basic sound is uncolored. In any event, why don't you think an audiophile quality speaker will do well in a home theater? The only complicating factor I can think of would be the tendency for HT soundtracks to run hot in the treble. But most HT receivers have tone controls..... As for reviews, I would love to have the ST's reviewed as widely as possible, but that's not really likely for speakers that aren't distributed through dealers. For the mainstream mags, dealer distribution is a necessary condition for a review. This is a rough biz.
Hi Dennis and Jim,There is an HT3 option to use a DEQX active crossover. Other than cost differences, what are the advantages/disadvantages of the active crossover versus the passive crossover? Will the SongTowers have an active crossover option? Best Regards
Kokishin - QuoteHi Dennis and Jim,There is an HT3 option to use a DEQX active crossover. Other than cost differences, what are the advantages/disadvantages of the active crossover versus the passive crossover? Will the SongTowers have an active crossover option? Best RegardsSince we are basically a custom builder, we can produce active versions of any of our speakers, including the SongTowers. But I don't feel it would make much sense in this case, even if you take cost out of the equation.DEQX is valuable in two main areas.First, it can correct for phase and frequency response deviations. But if you look at the the frequency response of the SongTowers, there just isn't anything that requires correction. And the phase tracking is very accurate in the crossover region. Hearing a stock SongTower will confirm this. So I doubt there would be any sonic difference offered by the DEQX in this area.The second main area is tailoring bass response to the room. But the SongTowers will load the room to a much lesser extent than, say, our HT3's. So gains to be made in this area are minimal at best unless the room is a major problem (in which case there are much less costly solutions like bass traps).Now, when you consider the cost of the DEQX ($3795) and the additional two channels of amplification required, it really does not make much sense for a speaker in this price range that already performs marvelously.That said, if someone wants it, we will be more than happy to produce an active pair.- Jim
