Imod input
0 Members and 1 Guest are viewing this topic. Read 1983 times.
cpk
Imod input
« on: 9 Aug 2007, 02:29 am »
Hello, I have received a 4g imod from Ken at ALO. I am very happy with the sq of this unit. I can plug in my Senn HD600s' to the headphone input and get decent volume from them. I thought that this was disabled and could only be used with  a headphone that had a volume control. As I stated the sq is pretty good, I would not think that the imod could power the 600s'. Could anyone please clarify this for me.
Vinnie R.
    • http://www.vinnierossi.com
Re: Imod input
« Reply #1 on: 9 Aug 2007, 12:49 pm »
Hi cpk,
Welcome to audiocircle and the RWA forum!
With the 4g iMods, the headphone jack has been converted to a modifed line-out.  This means that you won't be able to control the volume... it is a fixed 1Vrms output.  I don't recommend connecting headphones directly to this jack.  You really should use a headphone amp (with built-in volume control) to drive the low impedance of headphones, and so you can raise/lower the volume.
What you are doing now is kind of equivalent to using an RCA to female 1/8" stereo jack converter cable and plugging this into a home audio CD player.  Sure, you'll get sound out of your headphones, but the line-out stage is really designed to drive a higher impedance load... a headphone amp or home audio preamp/intergrated amp.
If you have any other questions, please let me know.
Enjoy your iMod!  8)
Vinnie
cpk
Re: Imod input
« Reply #2 on: 10 Aug 2007, 01:47 am »
Vinnie thanks for the info. I am using a RSA Original Hornet. I have about 300 hours on everything and really enjoying. I have just purchased a mini to rca. I will be using this with my 2 channel rig and posting my thoughts. By the way can I get an Imod sticker from you to put on this unit?
Thank You
Joe
Vinnie R.
Re: Imod input
« Reply #3 on: 10 Aug 2007, 01:05 pm »
Thank You
Joe
Hi Joe,
That iMod badge is something that I started for the 5G/5.5G iMods... not the 4G iMods.
Email me if you really want one for your 4G iMod: [email protected]
 :wink:
Vinnie
