FS - CONSONANCE A100 Linear Integrated AMP. 80wpc 8ohms... $600
0 Members and 1 Guest are viewing this topic. Read 2007 times.
Sonny
This awesome Integrated is a year old and used sparingly in the bedroom system...
Comes with remote and well, pristine!!!
Great for a second system or a modest first system.
New, it's $995 but I'll ask $600 for AC memebers...free shipping....
Thanks for looking!
See the link: http://www.opera-consonance.com/products/a100linear.htm
Specifications:
Power output : 80W + 80W at 8 Ohms
Minimum load : 4 ohms speakers can be connected.
Input Sources : 5 selectable inputs switched by gold plated relays
Input Terminals : Gold plated Phono/RCA unbalanced
Output Terminals : One set of gold plated speaker terminals each channel
Line level Outputs : Gold plated Phono/RCA unbalanced pre out
Frequency response : - 0.5 dB deviation 2Hz-100kHz
Phase response : Less than 2 degrees deviation 2Hz-100kHz
Signal-to-noise ratio : More than 95dB
Input Sensitivity : 500mV
Distortion : Less than 0.02% ( 20W 8 0hms)
Inter-modulation : Less than 0.01% (19kHz + 20kHz)
Remote Control : RC-5 compatible IR system 36kHz modulation
Sonny
bump!
great integrated!!!
Sonny
Great integrated!!!
bump.... :scratch:
