Working around RFI when using a tuner with Nuforce amps
0 Members and 1 Guest are viewing this topic. Read 1531 times.
DZetye
Hello,
I am auditioning the Nuforce amps and have found a way to rid the system of RFI with a tuner.  My solution was to listen to HD (digital) radio using the new Sangean HDT-1 HD radio tuner.  Evidently RFI does not affect HD radio broadcasts.  They can be bought for less than $200 so they are a pretty cheap solution if the station you like broadcasts in HD.
timothyharnett
Re: Working around RFI when using a tuner with Nuforce amps
« Reply #1 on: 9 Aug 2007, 01:17 am »
A better solution is to go for the V2 or upgrade to it.  I now have no such problems.
There was no way that I could give up FM in favour of digital radio because the difference in quality over here in the UK between the two mediums is so great.  I hope that the quality of your broadcasts are better than ours.
