"Dynamic range control" on the SP2, can someone explain it more to me?
0 Members and 1 Guest are viewing this topic. Read 1720 times.
Hoiman
Maybe it's my English but I think I don't really understand what "dynamic range control" does.
If it's set to 'LOW' what happens then, it sounds like the sound volume is better/louder and it sounds there is more base in the movie.
If the dynamic range control is in 'FULL' mode the sound is softer.
So I don't get the note that said: 'Caution should be exercised.....', in FULL mode?
So is there somebody out there that can give me more explanation of how the "dynamic range control" on the SP2 works?
« Last Edit: 7 Aug 2007, 10:54 am by Hoiman »
  • The Demo is Everything!
    • http://www.bryston.com
Use Full if your system is wide-bandwidth.
Mid setting slightly reduces the extreme lows and increases the mids (voice).
Low reduces the bandwidth even more and boosts the midbass/midband. It is a Dolby requirement that is suppose to allow for late night listening (low) by reducing the dynamic range in favour of a more pronounced midbass and midrange. The reason it sounds louder at the low setting is because it works by increasing gain in the middle and upper bass frequencies.
james
