0 Members and 1 Guest are viewing this topic. Read 2889 times.
They really do I recently had a contractor install my new, 52" sony XBR2 LCD. While doing this, I had him run a couple of conduits from the back of the TV, to a nearby closet, where most of my HT equipment will live. Seemed like a good plan. He ran a 1.5", and a 2.5" conduit, but since he was running the 2.5" (needed this for HDMI), he ran the conduit up to the ceiling, over, and then down into the closet. This translates into three 90 degree bends, and about a 20 foot run.He also installed pull strings, so I could pull the cables through the conduit.Last weekend, I started to try to run wires, but ran into problems. The wires would go so far, then stop. I was thinking that the connector ends were causing problems, but I was able to run a toslink cable through, and it had a pretty big connector ( it is the monoprice premium one). I did manage to get my HDMI cable in, but it was not easy.I even cut off the RCA from one of my component cables, ran a THHN wire through, soldered the THHN to the component, and tried to pull it that way, and even that did not work. Thats when I realized that with the three bends, there was too much friction from the rubber jacket against the conduit.Did a little looking on the internet, and found that they sell wire lubricant, just for this problem. Went to Home Depot today, and picked up quart of the stuff.So tonight, I tried running a SVGA cable that I could not run this weekend, and it worked, with the lubricant. BTW, if you just run THHN wire through conduit, it will probably be OK, since THHN has a slick outer coat on it.One other thing I did to help. I would tie the pull string just behind the connector, so it would not come off. But like this, the connector could become cocked, and have trouble pulling though. So, I put some take on the string, to tape the end of the connector to the string, and this makes it easier to pull the connector through the conduit.Thought I would share this, just in case somebody else ever runs into this problemRandy
For other people, Remember "Pull gently!"Cat 5 and 6, HDMI & Component cables don't like to be stretched or kinked. It messes up their high frequency response.
