0 Members and 1 Guest are viewing this topic. Read 4019 times.
Hi all, I was givin some money to buy a Talking Multimeter. The neat thing is it has a capacitance bridge, and a frequency counter. Now the question.:This particular meter will measure up to just under 400 Mils. Is that typical for any meter? I guess if you wanted to measure the current higher than 400 Mils, you'd have to use a set of resistors ahead of what you are measuring?Ray
Quote from: Ray Bronk on 4 Aug 2007, 12:02 amHi all, I was givin some money to buy a Talking Multimeter. The neat thing is it has a capacitance bridge, and a frequency counter. Now the question.:This particular meter will measure up to just under 400 Mils. Is that typical for any meter? I guess if you wanted to measure the current higher than 400 Mils, you'd have to use a set of resistors ahead of what you are measuring?RayHi Dan,You're probably right. Unfortunately, I have to get what is available. I think there is another Talking meter, but we're looking at something like $650 for it. This one is only $50. Don't know how good the accuracy is. RayMany of the Fluke meters will measure up to 10 amps if I remember correctly,but please feel free to check their web site.I would like to offer one word of advise to DIY folks. In many cases you really are better off spending more money on better test gear. I think good meters are one of them.d.b. d.b.
Ray, I meant to find my meter and check its current capacity earlier today, but have failed. I assume you are asking about current measurement (400 mA max). Mine would be either 200 mA or 2A. A typical multimeter is simply not built to handle high currents.In practice, for building DIY gear, I don't remember the last time I actually used current measurement. If you can measure a (differential) voltage and know a resistance value, the current is of course easily calculated. (For general work you don't need high precision.) If a higher current needs to be measured then a small resistor in the current path would be the way to do it. This is in fact how bias current in tube amps is measured, for instance.
If one of these is in your price range I would recommend it. Having an AC rms meter good from 20 Hz to 20 kHz sure comes in handy.http://www.techni-tool.com/static-products/fluke/374TE087.htmld.b.
Quote from: Dan Banquer on 4 Aug 2007, 03:37 pmIf one of these is in your price range I would recommend it. Having an AC rms meter good from 20 Hz to 20 kHz sure comes in handy.http://www.techni-tool.com/static-products/fluke/374TE087.htmld.b.You keep missing that he is looking for an audible meter. Ray has vison problems and can't see the screen on the ones you keep recommending.
There may be some additional possibilities here:http://www.audiocircle.com/index.php?topic=43861.0Your basic premise is sound: get the info onto a computer and go from there. d.b.
